Tables as Objects ​
Lua does not have built-in classes, but it supports object-oriented programming through tables and functions. By storing data and behavior together inside a table, we can create objects that represent entities with state and actions.
What Is an Object in Lua? ​
An object in Lua is typically: a table that stores data (fields) functions inside the table that operate on that data (methods)
local player = {
    name = "Alex",
    score = 0
This table represents an object with state.
Adding Methods to a Table ​
Methods are functions stored in a table.
function player:add_score(points)
    self.score = self.score + points
Calling the method:
player:add_score(10)
print(player.score)
The self parameter refers to the table itself.
The : vs . Syntax ​
Using : automatically passes the table as the first argument.
Is equivalent to:
player.add_score(player, 10)
Using : is recommended for methods.
Creating Multiple Objects ​
To create multiple similar objects, a constructor function is commonly used.
function new_player(name)
    return {
        name = name,
        score = 0
local p1 = new_player("Alice")
local p2 = new_player("Bob")
Sharing Methods Between Objects ​
Instead of duplicating methods, they can be shared using a common table.
Player = {}
function Player:add_score(points)
    return {
        name = name,
        score = 0,
        add_score = Player.add_score
This reduces duplication, but still has limitations.
Introducing a Prototype Table ​
A more common pattern uses a prototype table.
Player = {}
Player.__index = Player
function Player:new(name)
    local obj = {
        name = name,
        score = 0
    setmetatable(obj, Player)
    return obj
Creating objects:
local p1 = Player:new("Alice")
local p2 = Player:new("Bob")
p1:add_score(10)
p2:add_score(5)
Encapsulation by Convention ​
Lua does not enforce private fields, but conventions are used.
local Player = {}
    local obj = {
        _name = name,
        _score = 0
    setmetatable(obj, self)
    self.__index = self
    return obj
A leading underscore indicates internal use.
Objects and State ​
Each object has its own independent state.
p1:add_score(10)
p2:add_score(5)
print(p1.score)  -- 10
print(p2.score)  -- 5
Common Mistakes ​
Forgetting self in method definitions:
function Player.add_score(points)  -- wrong
Calling a method with . instead of ::
p1.add_score(10)  -- wrong
In Lua, objects are built using tables and functions. Methods operate on object state through the self parameter. Constructor functions and prototype tables allow the creation of multiple objects that share behavior. This flexible
approach forms the basis of object-oriented programming in Lua.
