System Exclusive (SysEx) Messages ​
System Exclusive (SysEx) messages are a special type of MIDI message that allow manufacturer-specific communication. Unlike standard MIDI messages, SysEx can carry arbitrary data, making it possible to configure devices, exchange presets and access features that standard MIDI cannot represent.
Why SysEx Exists ​
Standard MIDI messages are limited:
  • fixed message types
  • small number of parameters
  • predefined meanings
Manufacturers needed a way to:
  • expose advanced features
  • transfer large data blocks
  • support device-specific protocols
SysEx provides this flexibility.
Basic Structure of a SysEx Message ​
Every SysEx message has the same outer structure:
F0 <manufacturer ID> <data bytes...> F7
Where:
  • F0 — SysEx start
  • F7 — SysEx end
  • everything in between is manufacturer-defined
Manufacturer ID ​
The Manufacturer ID identifies which company the message is intended for. Examples:
  • 41 — Roland
  • 43 — Yamaha
  • 7D — Educational / non-commercial
  • 3-byte IDs for newer manufacturers
This ensures that devices ignore SysEx messages not meant for them.
Why SysEx Uses Only 7-bit Data Bytes ​
SysEx data bytes must be in the range:
0x00 – 0x7F
This avoids:
  • accidental interpretation as status bytes
  • interference with running status
  • parsing ambiguity
Larger values are split across multiple bytes using bit masking and shifting.
SysEx and MIDI Channels ​
SysEx messages are not tied to MIDI channels.
Instead:
  • they target devices, not parts
  • all devices receive them
  • devices decide whether to respond
Because of this, SysEx protocols include their own addressing.
Device IDs ​
Since SysEx is channel-independent, many protocols include a Device ID inside the message. Example:
F0 <manufacturer> <device ID> <command> <data> F7
Purpose of Device IDs
  • distinguish multiple devices of the same type
  • replace MIDI channel addressing
  • allow broadcast or targeted messages
Common conventions:
  • 0x7F = all devices
  • 0x00–0x0F = individual device numbers
Common SysEx Message Patterns ​
Although SysEx content is manufacturer-defined, most protocols follow common patterns.
Command-Based SysEx ​
Many SysEx messages include a command byte.
F0 <mfg> <device> <command> <data> F7
Typical commands:
  • set parameter
  • request data
  • write memory
  • read memory
Request–Response Pattern ​
One of the most common SysEx use cases is requesting data from a device.
Step 1: Send a Request ​
F0 <mfg> <device> <request command> <address> F7
This tells the device: “Please send me this data.”
Step 2: Device Sends a Response ​
F0 <mfg> <device> <response command> <data> F7
The response may:
  • contain parameter values
  • include checksums
  • be split into multiple messages
Why Data Is Often Requested Instead of Pushed ​
SysEx is often pull-based:
  • controllers ask for data
  • devices respond when ready
This avoids:
  • flooding the MIDI bus
  • sending unnecessary data
  • synchronization issues
Checksums ​
Many SysEx protocols include a checksum. Purpose:
  • detect transmission errors
  • validate data integrity
Checksums are usually:
  • simple sums
  • masked to 7 bits
Common SysEx Use Cases ​
Parameter Editing ​
Change a specific parameter:
F0 <mfg> <device> <set param> <param ID> <value> F7
Patch and Preset Dumps ​
Transfer large blocks of data:
  • single patch
  • entire bank
  • global settings
These messages may contain hundreds of bytes.
Device Configuration ​
  • MIDI routing
  • mode selection
  • calibration
  • system settings
Device Identification ​
Some devices respond to an identity request.
F0 7E <device> 06 01 F7
Response identifies:
  • manufacturer
  • model
  • version
Why SysEx Protocols Are Custom ​
SysEx is not standardized beyond its framing. This allows:
  • innovation
  • proprietary features
  • device-specific workflows
The downside:
  • documentation is essential
  • each device must be handled individually
System Real-Time Messages Inside SysEx ​
Critical Rule System Real-Time messages are allowed to appear inside SysEx messages. Example stream:
F0 43 10 4C
F8
00 01 02
F8
03 04 F7
The real-time messages: interrupt the SysEx stream must be processed immediately do not break or terminate the SysEx message After processing the real-time message, SysEx parsing resumes.
SysEx messages provide a flexible, manufacturer-specific extension to MIDI. They are framed by standard start and end bytes but contain custom data defined by each device. SysEx is channel-independent and often uses device IDs for addressing. Common patterns include command-based messages and request–response exchanges for reading and writing data. SysEx enables advanced control, configuration, and data transfer that is not possible with standard MIDI messages.
