Lua extension
This document describes the Lua Extension for the Electra One MIDI Controller firmware. The extension introduces procedural programming capabilities to Electra One presets
Lua is a lightweight scripting language. You can find detailed information on the Official Lua site. Alternatively, you can follow our Lua Crash Course — a short tutorial designed specifically for musicians and non-programmers.
With the Electra Lua extension, you can use the Lua programming language inside Electra One MIDI controllers to easily create, manage, and customize MIDI and music-related actions.
To utilize the Electra One Lua Extension described in this document, you must have Firmware version 4.0 or later installed.
A brief overview
With the Electra One Lua extension, you can extend and customize your presets by adding Lua functions. It allows you to create features and behaviors that simply wouldn't be possible without it. Here are just a few examples of what you can do:
  • Send and receive MIDI messages.
  • Trigger Lua functions when control values change.
  • Format display values.
  • Modify the visibility, location, name, and color of controls.
  • Execute custom patch dump request calls.
  • Craft your own SysEx parsers.
  • Calculate checksums and generating custom SysEx template bytes.
  • Run Lua functions based on MIDI clock and transport control.
  • Create sequences of MIDI data, clock messages, and MIDI LFOs.
  • Visualize MIDI data on the controller's screen.
The core idea behind this extension is to clearly separate the static data defined in the declarative JSON preset from the dynamic processing handled at runtime through Lua scripting. The JSON preset acts as the foundation, pre-loading all pages, lists, devices, groups, and controls. Once the preset is loaded, the Lua extension takes over, allowing you to manipulate these objects for specific purposes.
It's important to note that the Lua extension cannot create new objects, but it can modify, reposition, and change the visibility of existing ones.
Uploading the scripts
To enable Lua extension functions within a preset, you must first upload a Lua script file(s). The uploaded script is then associated with the currently active preset. If a Lua script already exists for that preset, uploading a new one will overwrite it.
Normally, each preset uses a single Lua script. If needed, you can upload multiple Lua script files that work together as one larger Lua project.
This document covers the single-file setup. Multi-file configurations are explained in a separate guide about Electra One’s file transfer and management protocol.
Uploading the scripts with the Preset Editor
You can create, edit, and upload Lua scripts directly from the Preset editor — the easiest and recommended way to work with Lua. If needed, you can also upload scripts to the Electra One MIDI Controller using a SysEx call.
Uploading the scripts with a SysEx call
0xF0 0x00 0x21 0x45 0x01 0x0C script-source-code 0xF7
Executing a Lua command with a SysEx call
This is a call that executes arbitrary Lua commands, effectively serving as an API endpoint for controlling Electra One presets from external devices and applications.
It allows you to remotely manage Electra One presets using Lua commands, offering a powerful way to interact with the controller from external sources. The maximum allowed length of a Lua command is 65,353 bytes.
However, we recommend keeping commands short — commands shorter than 65 bytes are executed significantly faster than longer ones.
To optimize performance, it is better to use this SysEx call to trigger Lua functions defined in a previously uploaded Lua script, rather than sending large blocks of arbitrary Lua code.
0xF0 0x00 0x21 0x45 0x08 0x0D lua-command-text 0xF7
lua-command-text is a free-form string that holds the Lua command to be executed. It must respect the maximum length limit explained above.
An example of the lua-command-text
print ("Hello MIDI world!")
The structure of the script
The Electra One Lua Extension script is organized into four distinct building blocks:
  • The Setup Section: This section is where you initialize and configure the settings and parameters needed for your script. It acts as the starting point for your script’s execution and often includes setup tasks like defining global variables, establishing MIDI connections, or configuring other necessary resources.
  • The Standard Functions: These are predefined functions included in the Electra One Lua Extension scripting environment. They provide the core functionality for interacting with the MIDI controller and its features. Standard functions can be used to send and receive MIDI messages, manipulate controls, and manage various aspects of the controller's behavior.
  • The Standard Callbacks: Electra One provides a set of standard callback functions that allow your Lua script to respond to various events. These callbacks are invoked automatically by the system when specific events occur. For example, you can use callbacks to react to control value changes or button presses, adding dynamic and interactive behavior to your script.
  • The User Functions: These are custom functions that you define to extend the functionality of your Lua script. User functions allow you to implement unique behaviors, process data, and create specific responses to tailor the script to your needs. They give you the flexibility to customize the Electra One experience according to your requirements.
Once you understand and use these four building blocks, you’ll be able to create powerful Lua scripts that make your Electra One MIDI controller even more capable and flexible.
Let's use the following example to demonstrate it:
-- Display controls related to specific value of another control
-- a function to hide all controls within the groups
function hideAllGroups(groups)
    for groupId = 0, #groups do
        for i, controlId in ipairs(groups[groupId]) do
            control = controls.get(controlId)
            control:setVisible(false)
-- show given control group
function showGroup(groups, groupId)
        control:setSlot(i + 1)
-- the callback function called from the preset
function displayGroup(valueObject, value)
    hideAllGroups(controlGroups)
    showGroup(controlGroups, value)
-- a standard callback function to handle PATCH REQUEST event
function patch.onRequest(device)
    print("Requesting patches from device " .. device.id);
    midi.sendProgramChange(PORT_1, device.channel, 10)
-- set the initial state. group 0 is displayed
-- define assignment of controls to groups
controlGroups = {
    [0] = { 20, 21, 22 },
    [1] = { 26, 27, 28 },
    [2] = { 32, 33 }
function preset.onLoad()
    showGroup(controlGroups, 0)
print("Lua ext initialized")
The setup
The setup section includes all source code that exists outside of any specific function and runs in the global context of the script. In this section, you can perform various tasks such as calling standard functions, executing user-defined functions, initializing global variables, and setting up resources.
Below is an example of a typical setup section from a script:
controlGroups = {
    [2] = { 32, 33 }
The primary purpose of the setup section is to prepare your extension to handle application events later on. It is executed immediately after the preset is loaded.
The location of the setup code within the script does not affect its functionality — it does not have to be placed at the top. However, if you plan to call your own user-defined functions in the setup section, it’s recommended to either place the setup code after the function definitions or move it into the preset.onLoad() or preset.onReady() functions for better script organization. For more details, see the Preset Initialization section below.
The standard functions
Standard functions include functions from both the Lua standard libraries and the Electra One Extension libraries. They cover a wide range of tasks, such as printing messages, performing mathematical operations, sending and receiving MIDI messages, and interacting with user interface (UI) components.
You can find detailed descriptions of the Lua standard functions in the official Lua documentation, and descriptions of Electra-specific functions in the API Reference later in this document.
As an example, the print function is a typical standard function you will use in your scripts:
The standard callbacks
The Electra One Lua Extension provides a set of predefined event handlers, often called callbacks. These callbacks are automatically triggered when specific events happen.
For example:
In this code snippet, the patch.onRequest function is a standard callback that responds to the 'PATCH REQUEST' event. When the event occurs, this callback runs the actions you have defined: printing a text message and sending out a Program Change MIDI message.
Standard callbacks like this allow you to customize how your Lua script reacts to different events, making your Electra One MIDI controller more interactive and adaptable.
The user functions
As a user, you have the creative freedom to define your own functions. In fact, you are encouraged to do so — user functions are the building blocks for creating more advanced and structured elements in your Lua script.
User functions help you organize your code and extend your script’s capabilities. They let you group specific tasks or behaviors together, making your scripts more modular, easier to manage, and easier to reuse.
For example, the displayGroup function from the earlier source code example is a user-defined function that is linked to a callback hook inside the preset JSON.
Preset initialization
Some presets may require a carefully controlled sequence of actions during startup. The Electra One Lua Extension gives you ways to run your own functions at different stages of the preset loading process. It’s important to understand the order in which these stages happen.
When a preset is loaded for the first time. For example, when you power on the controller — the following steps take place:
  1. Everything defined in the global context of your Lua script (outside of any function) is executed.
  2. The preset.onLoad() function is called, if defined.
  3. All Lua functions linked to Control values are called, using the default values from the preset JSON.
  4. The preset.onReady() function is called, if defined.
  5. The preset.onEnter() function is called, if defined.
  6. Electra One starts listening for external events, like user actions or incoming MIDI messages.
The same sequence of actions is performed when you load any preset for the first time — for example, when switching presets using the user interface. Once a preset has been loaded, switching back to it later will not re-initialize it. The preset is considered already initialized.
Lua Extension API Reference
This section provides a complete reference to all Lua functions available in the Electra One Extension library. You’ll find descriptions, parameters, and usage details for each function, organized by category. These functions allow your script to interact with controls, MIDI messages, graphics, system settings, and more. Use this chapter as a practical guide while developing or exploring your Lua scripts.
Controls
The controls module provides functionality to manage preset controls. It is not intended for changing properties of individual controls. Individual controls are managed by manipulating the Control object.
Functions
controls.get(ref)
Retrieves a reference to a Control object (Lua userdata). A control represents a fader, list, or other type of control. The reference number can be found in the control properties panel in the Preset Editor.
Parameters
ref
number, a preset object reference number (1 .. 1023).
Returns
userdata, an object representing the control.
Example
-- Retrieving a reference to given control
local control = controls.get(1)
Control
A Control object represents a single control, like a fader or button. It stores its own data and provides functions to read and update its properties.
Functions
<control>:getId()
Retrieves an identifier of the Control. The identifier is assigned to the Control in the preset JSON.
Returns
number, the reference of the control (1 .. 1023).
Example
-- Retrieving a control and getting its Id
local volumeControl = controls.get(10)
print("got Control with Id " .. volumeControl:getId())
<control>:setVisible(shouldBeVisible)
Changes the visibility of the given control. The initial visibility is defined in the Preset JSON. The setVisibility() function can update the visibility at runtime.
Parameters
shouldBeVisible
boolean, true when the Control will be visible.
<control>:isVisible()
Retrieves the visibility status of the control.
Returns
boolean, true when the control is currently visible.
Example
-- a function to toggle visibility of a control
function toggleControl(control)
    control:setVisible(not control:isVisible())
<control>:setName(name)
Sets a new name of the control.
Parameters
name
string, the new name to assign to the control.
<control>:getName()
Retrieves the current name of the control.
Returns
string, the current name of the control.
Example
-- print out a name of given control
function printName(controlId)
    local control = controls.get(controlId)
    print ("Name: " .. control:getName())
<control>:setColor(color)
Sets a new color for the control. Although 24-bit RGB 888 is used, the controller internally converts it to 16-bit RGB 565.
Parameters
color
number, a number representing the color as a 24-bit RGB value.
<control>:getColor()
Retrieves the current color of the control.
Returns
Example
-- A callback function that changes color of the control
-- when its value exceeds 100
function functionCallback(valueObject, value)
    local control = valueObject:getControl()
    if (value > 100) then
        control:setColor(0xff0000)
    else
        control:setColor (0xffffff)
<control>:setVariant(variant)
Sets a variant for the control. For a list of variants, see the Globals section below.
Parameters
variant
number, a number representing the variant.
<control>:getVariant()
Retrieves the current variant of the control.
Returns
<control>:setBounds({x, y, width, height})
Sets the bounding box (position and dimensions) of the control on the screen. The function expects an array to be passed as an argument. Use the X, Y, WIDTH, HEIGHTglobals to access individual members of the array.
Parameters
x
number, X position on the screen.
y
number, Y position on the screen.
width
number, width of the control.
height
number, height of the control.
<control>:getBounds()
Retrieves the bounding box (position and dimensions) of the control on the screen. Use the X, Y, WIDTH, HEIGHTglobals to access individual members of the array.
Returns
array, an array consisting of x, y, width, height boundary box attributes.
Example
-- print out position and dimensions of given control
local control = controls.get(2)
control:setBounds({ 200, 200, 170, 65 })
bounds = control:getBounds()
print("current bounds: " ..
    "x=" .. bounds[X] ..
    ", y=" .. bounds[Y] ..
    ", width=" .. bounds[WIDTH] ..
    ", height=" .. bounds[HEIGHT])
<control>:setPot(controlSet, pot)
Assigns the control to a specified control set and pot. See the Globals section below for available Control Set and pot identifiers.
Parameters
controlSet
number, a numeric identifier of the Control Set to assign.
pot
number, a numeric identifier of the pot.
Example
-- Reassign the control to different controlSet and pot
control:setPot(CONTROL_SET_1, POT_2)
<control>:setSlot(slot)
Moves the given control to a preset slot on the current page. The Control Set and pot values are assigned automatically, and the control is made visible.
Parameters
slot
number, a numeric identifier of the page slot (1 .. 36).
<control>:setSlot(slot, page)
Moves the given control to a preset slot on a specified page. The Control Set and pot values are assigned automatically, and the control is made visible. This function is a variant of setSlot(slot), allowing you to specify the target page as well.
Parameters
slot
page
number, a numeric identifier of the page (1 .. 12).
Example
-- Change location of the control within the 6x6 grid
control:setSlot(7)
<control>:getValueIds()
Retrieves a list of all valueIds associated with the control. The valueIds are defined in the preset JSON. Retrieved valueIds, eg. value, attack can be used as parameters for the <control>:getValue(valueId) function.
Returns
array, a list of value identifier strings.
Example
-- list all value Ids of a control
local valueIds = control:getValueIds ()
for i, valueId in ipairs(valueIds) do
    print(valueId)
Retrieves the Value object of the given control using the valueId handle. The valueId is defined in the preset JSON. If not specified, value will be used as the default valueId. List of available valueIds:
  • value
  • attack
  • decay
  • slope
  • break
  • sustain
  • release
  • x
  • y
  • l1
  • r1
  • l2
  • r2
  • l3
  • r3
  • l4
  • r4
Parameters
valueId
string, a text that identifies a specific value of a control.
Returns
userdata, a reference to the Value object.
Example
-- Display min and max display values
local value = control:getValue("attack")
print ("value min: " .. value:getMin())
print ("value max: " .. value:getMax())
<control>:getValues()
Retrieves a list of all Value objects associated with the control. The value objects are defined in the JSON preset.
Returns
array, a list of references to userdata Value objects.
Example
-- list all value objects of a control
local valueObjects = control:getValues()
for i, valueObject in ipairs(valueObjects) do
    print(string.format ("%s.%s", control:getName(), valueObject:getId()))
<control>:setPaintCallback(callback)
Assigns a function that defines how the control is drawn. This can only be used with Custom controls.
Parameters
callback
function, a reference to a Lua function.
<control>:setTouchCallback(callback)
Assigns a function that will be called when a display touch event is received for the given Custom control.
Parameters
callback
<control>:setPotCallback(callback)
Assigns a function that will be called when a pot change event is received for the given Custom control.
Parameters
callback
<control>:repaint()
Schedules a repaint of the control. The function is meant to be used inside the Custom control touch and pot change callbacks.
<control>:print()
Prints all attributes of the Control object to the Logger output.
Controller
The controller module provides functionality to query information about the controller hardware and the firmware, and to check compatibility.
Functions
getModel()
Retrieves information about the model of the controller.
Returns
enum, ['mk2', 'mini'].
getNumModel()
Retrieves numeric information about the model of the controller.
Returns
enum, [MODEL_MK2, MODEL_MINI].
getFirmwareVersion()
Retrieves version of the firmware currently installed in the controller.
Returns
string, a text representation of the firmware version.
getFirmwareNumVersion()
Retrieves numeric version of the firmware currently installed in the controller.
Returns
number, a numeric representation of the firmware version.
uptime()
Retrieves the number of milliseconds elapsed since the controller was reset.
Returns
number, time elapsed in milliseconds.
require(model, minimumVersion)
Raises an error when the model and minimum firmware version requirements are not met. The function is meant to be used in combination with an assert() function.
Parameters
model
number, numeric information about the model of the controller.
minimumVersion
string, minimum required version of the firmware.
isRequired(model, minimumVersion)
Checks the model of the controller and the version of the currently installed firmware. Returns information on whether the requirements are met.
Parameters
model
minimumVersion
Returns
boolean, true if the requirements are met.
Example
-- Check if model and firmware requirements are met
-- Note: assert will terminate the script on a failed check
assert(
    controller.isRequired(MODEL_MK2, "4.0.0"),
    "Version 4.0.0 or higher is required"
-- Note: this will not terminate the script
local validToRun = controller.isRequired(MODEL_MK2, "4.0.1")
if validToRun == true then
  print("requirements met")
else
  print("requirements failed")
-- Query information about the controller and the firmware
print("model: " .. controller.getModel())
print("numeric model: " .. controller.getNumModel())
print("firmware version: " .. controller.getFirmwareVersion())
print("numeric firmware version: " .. controller.getFirmwareNumVersion())
-- Query system uptime
print("uptime: " .. controller.uptime() .. " msecs")
Data Pipe
Data pipes let presets share information with each other. Think of a data pipe as a named channel where one preset can send a stream of numbers, and another preset can receive them.
This is useful when you want different presets to work together. For example, you can create an LFO preset that continuously sends out modulation values. Another preset can then receive that stream and use it to control things like knobs or sliders — without changing its own internal setup.
This makes it easy to build flexible and creative setups where presets interact in real time.
Functions
pipe.acquire(pipeName)
Creates a new data pipe with a name. Other presets can listen to that pipe and receive any data sent by the preset that owns it.
Parameters
pipeName
string, name of the data pipe channel.
Returns
number, a numeric identifier of the pipe channel.
pipe.send(pipeId, value)
Sends a floating-point number to a data pipe that was previously acquired using the `pipe.acquire()` function. The value will be delivered to all presets that are listening to that pipe.
Parameters
pipeId
number, a numeric identifier of the pipe to send the data to.
value
number, a floating-point number to send.
pipe.release(pipeId)
Releases a previously acquired pipe, making the pipeId available for other presets to use.
Parameters
pipeId
Devices
A Device represents a musical instrument connected to one of Electra’s hardware ports and listening on a particular MIDI channel. The devices module provides functionality to query and create devices.
Functions
devices.get(deviceId)
Retrieves a reference to a Device object (Lua userdata). A Device represents a MIDI device that sends and receives messages with the controller.
Parameters
deviceId
number, a numeric identifier of the device (1 .. 32).
Returns
userdata, an object representing the device.
devices.getByPortChannel(port, channel)
Retrieves a reference to a Device object (Lua userdata) using the port and MIDI channel. A Device represents a MIDI device that sends and receives messages with the controller.
Parameters
port
enum, a numeric identifier of the port [PORT_1, PORT_2]
channel
number, a numeric identifier of the MIDI channel (1 .. 16).
Returns
devices.create(deviceId, name, port, channel)
Creates a new Device object and returns a reference to it.
Parameters
deviceId
number, a numeric identifier of device to be created.
name
string, a name to be assigned to the device.
port
channel
Returns
Device
A Device object is used to manage the Device settings.
Functions
<device>:getId()
Retrieves an identifier of the Device. The identifier is assigned to the control in the preset JSON or created with the devices.create() function.
Returns
<device>.setName(name)
Assigns a new name to the Device.
Parameters
name
string, a name to be assigned to the Device.
<device>.getName()
Retrieves the name currently assigned to the Device.
Returns
string, a name currently assigned to the Device.
<device>.setPort(port)
Assigns a new MIDI port to the Device.
Parameters
port
<device>.getPort()
Retrieves the currently assigned MIDI port.
Returns
<device>.setChannel(channel)
Assigns a new MIDI channel to the Device.
Parameters
channel
<device>.getChannel()
Retrieves the currently assigned MIDI channel.
Returns
<device>.setRate(time)
Sets the time delay between sending individual MIDI messages.
Parameters
rate
number, the time delay in msecs to be set.
<device>.getRate()
Retrieves the current time delay between sending individual MIDI messages.
Returns
number, the time delay in milliseconds.
Example
-- This needs to reflect the preset device settings
local AccessVirusDeviceId = 2
-- Display info about the device
local device = devices.get(AccessVirusDeviceId)
print ("device port: " .. device:getPort())
print ("device channel: " .. device:getChannel())
-- A function to set channel of device with a Control
function setChannel(control, value)
    device:setChannel(value)
Events
The Events library lets you control which notifications Electra One sends out and define callback functions to handle those events.
Functions
events.subscribe(eventFlags)
A function to instruct the controller what event notifications should be emitted. Subscribed events are result in calls to event callback functions and sending out SysEx event notifications.
Parameters
eventFlags
number, a byte where each bit represents an event type to be subscribed. Note, currently only `PAGES` and `POTS` are supported.
Example
-- Sending MIDI messages out
print ("Events demo")
events.subscribe(PAGES | POTS)
events.setPort(PORT_CTRL)
function events.onPageChange(newPageId, oldPageId)
  print ("old: " .. oldPageId)
  print ("new:" .. newPageId)
function events.onPotTouch(potId, controlId, touched)
  print ("potId: " .. potId)
  print ("controlId: " .. controlId)
  print ("touched: " .. (touched and "yes" or "no"))
events.setPort(port)
Sets MIDI port that will be used to send out event notifications.
Parameters
port
enum, a numeric representation of the MIDI port [PORT_1, PORT_2, PORT_CTRL].
A callback function that runs automatically when the user switches to a different page. The function is called only if Page change notifications have been subscribed to. For more details, see Events section.
Parameters
newPageId
number, a numeric identifier of the Page being activated (1–12).
oldPageId
number, a numeric identifier of the Page being left (1–12).
events.onPotTouchChange(potId, controlId, touched)
A callback function that is called when user touches or releases the controller knobs.
Parameters
potId
number, a numeric identifier of the Pot being touched (1–12).
controlId
touched
boolean, when true the Pot has an active touch, otherwise it was released.
Graphics
The Graphics module provides drawing functions for use within component paint callbacks. Drawing is restricted to the area defined by each component's boundary box.
Technically, it is possible to call the drawing functions outside of the component paint callbacks. However, in such cases, the drawing will not be synchronized with the component repaints, which may result in flickering, overpainting, or the drawings being invisible.
Functions
graphics.setColor(color)
Sets the color used by all following drawing functions.
Parameters
color
graphics.drawPixel(x1, y1)
Draws single pixel at (x, y) coordinates.
Parameters
x
number, X position of the starting point of the line.
y
number, Y position on the starting point of the line.
graphics.drawLine(x1, y1, x2, y2)
Draws a straight line between (x1, y2) staring coordinates and (x2, y2) ending coordinates.
Parameters
x1
y1
x2
number, X position on the ending point of the line.
y2
number, Y position on the ending point of the line.
graphics.drawRect(x, y, width, height)
Draws a rectangle starting at the (x, y) coordinates, using the specified width and height.
Parameters
x
number, X position of the left-top corner of the rectangle.
y
number, Y position on the left-top corner of the rectangle.
width
number, width of the rectangle.
height
number, height of the rectangle.
graphics.fillRect(x, y, width, height)
Draws a solid-filled rectangle at the (x, y) coordinates with the given width and height.
Parameters
x
y
width
height
graphics.drawRoundRect(x, y, width, height, radius)
Draws a rounded rectangle starting at the (x, y) coordinates, using the specified width and height.
Parameters
x
y
width
height
radius
number, radius to be applied at the corner.
graphics.fillRoundRect(x, y, width, height, radius)
Draws a solid-filled rounded rectangle at the (x, y) coordinates with the given width and height.
Parameters
x
y
width
height
radius
graphics.drawTriangle(x1, y1, x2, y2, x3, y3)
Draws a triangle by connecting the three specified coordinates (x1, y1), (x2, y2), and (x3, y3).
Parameters
x1
number, X-coordinate of the first vertex.
y1
number, Y-coordinate of the first vertex.
x2
number, X-coordinate of the second vertex.
y2
number, Y-coordinate of the second vertex.
x3
number, X-coordinate of the third vertex.
y3
number, Y-coordinate of the third vertex.
graphics.fillTriangle(x1, y1, x2, y2, x3, y3)
Draws a filled triangle by connecting the three coordinates points (x1, y1), (x2, y2), and (x3, y3) and filling the interior area.
Parameters
x1
y1
x2
y2
x3
y3
graphics.drawCircle(x, y, radius)
Draws the outline of a circle centered at (x, y) coordinates with the specified radius.
Parameters
x
number, X-coordinate of the center of the circle.
y
number, Y-coordinate of the center of the circle.
radius
number, radius of the circle.
graphics.fillCircle(x, y, radius)
Draws a filled circle centered at (x, y) coordinates with the specified radius.
Parameters
x
y
radius
graphics.drawEllipse(x, y, radiusX, radiusY)
Draws the outline of an ellipse centered at (x, y) coordinates with the specified horizontal and vertical radius.
Parameters
x
number, X-coordinate of the center of the ellipse.
y
number, Y-coordinate of the center of the ellipse.
radiusX
number, horizontal radius of the ellipse.
radiusY
number, vertical radius of the ellipse.
graphics.fillEllipse(x, y, radiusX, radiusY)
Draws a filled ellipse centered at (x, y) coordinates with the specified horizontal and vertical radius.
Parameters
x
y
radiusX
radiusY
graphics.fillCurve(x, y, radius, segment)
Draws a filled circular segment (curve) centered at (x, y) coordinates with the specified radius and segment.
Parameters
x
number, X-coordinate of the center of the curve.
y
number, Y-coordinate of the center of the curve.
radius
number, radius of the curve.
segment
enum, segment of the circle to be drawn [TOP_LEFT, TOP_RIGHT, BOTTOM_LEFT, BOTTOM_RIGHT].
graphics.print(x, y, text, width, alignment)
Prints text starting at the (x, y) position, using the specified width and alignment.
Parameters
x
number, X-coordinate where the text starts.
y
number, Y-coordinate where the text starts.
text
string, the text to be printed.
width
number, the width of the box where the text is printed.
alignment
enum, text alignment inside the box [LEFT, CENTER, RIGHT].
Groups
The groups module helps you manage groups inside a preset. A Group is a graphical element that organizes and improves the layout of preset pages.
Functions
groups.get(ref)
Retrieves a reference to a Group object (Lua userdata).
Parameters
ref
number, a preset object reference number.
Returns
userdata, an object representing the Group.
Example
-- Retrieve a reference to given group
local group = groups.get(1)
Group
A Group object stores its own data and provides functions to update and manage it.
Functions
<group>:getId()
Retrieves an identifier of the Group. The identifier is assigned to the Control in the preset JSON.
Returns
number, the reference of the Group (1 .. 1023).
<group>:setLabel(label)
Sets a new label of the Group.
Parameters
label
string, the new labek to assign to the Group.
<group>:getLabel()
Retrieves the current label assigned to the Group.
Returns
string, the current label of the Group.
<group>:setVisible(shouldBeVisible)
Changes the visibility of the given Group. The initial visibility is defined in the Preset JSON. The setVisibility() function can update the visibility at runtime.
Parameters
shouldBeVisible
boolean, true when the Group will be visible.
<group>:isVisible()
Retrieves the visibility status of the Group.
Returns
boolean, true when the Group is currently visible.
<group>:setColor(color)
Sets a new color for the Group. Although 24-bit RGB 888 is used, the controller internally converts it to 16-bit RGB 565.
Parameters
color
<group>:getColor()
Retrieves the current color of the Group.
Returns
<group>:setVariant(variant)
Sets a variant for the Group. For a list of variants, see the Globals section below.
Parameters
variant
enum, a number representing the variant [VT_DEFAULT, VT_HIGHLIGHTED].
<group>:setBounds({x, y, width, height})
Sets the bounding box (position and dimensions) of the Group on the screen. The function expects an array to be passed as an argument. Use the X, Y, WIDTH, HEIGHTglobals to access individual members of the array.
Parameters
x
y
width
number, width of the Group.
height
number, height of the Group.
<group>:getBounds()
Retrieves the bounding box (position and dimensions) of the Group on the screen. Use the X, Y, WIDTH, HEIGHTglobals to access individual members of the array.
Returns
Example
-- change group slot and dimentions
-- Verical line only
local group1 = groups.get(1)
print("Label name: " .. group1:getLabel())
group1:setSlot(3, 2)
-- Renctangle group
local group2 = groups.get(2)
print("Label name: " .. group2:getLabel())
group2:setSlot(9, 2, 2)
<group>:setSlot(slot, width, height)
Moves the given Group to a preset slot on the current page and adjusts its horizontal and vertical span. A height of 0 creates a thin line; any other height setting forms a rectangle.
Parameters
slot
width
number, a horizontal span of the Group in the slot units (1 .. 6).
height
number optional, a vertical span of the Group in the slot units (0 .. 6).
<group>:setHorizontalSpan(width)
Changes the horizontal span of the group.
Parameters
width
<group>:setVerticalSpan(width)
Changes the vertical span of the group. A height of 0 creates a thin line; any other height setting forms a rectangle.
Parameters
height
number, a vertical span of the Group in the slot units (0 .. 6).
<group>:print()
Prints all attributes of the Group object to the Logger output.
Helpers
The helpers library consists of helper functions to make handling of certain common situations easier.
Functions
delay(millis)
Waits for the specified amount of time. Note: the `delay()` function pauses the execution of the internal thread that called it, which, in most cases, is the main application thread executing Lua commands. This means it will not block other functionality, such as the processing of MIDI callbacks. However, since this can lead to tricky situations, use the function sparingly.
Parameters
millis
number, a time delay to wait milliseconds (1 .. 5000)
slotToBounds(slot)
Converts a preset slot to a boundary box data table.
Parameters
slot
Returns
boundsToSlot(({x, y, width, height})
Converts a bounding box (bounds) to slot.
Parameters
x
y
width
height
Returns
Example
-- Move control to given slot
control:setBounds(helpers.slotToBounds (6))
Info
The Info library lets you show custom text messages in the status bar at the bottom of the screen.
Functions
info.setText(text)
A function retrieve the text shown in the bottom status bar.
Parameters
text
string, a text message to be displayed.
Returns
string, a text currently shown in the status bar at the bottom of the screen.
Example
-- Display an info text
info.setText("Hello world")
info.getText()
A function to to display the text in the bottom status bar.
Parameters
text
Example
-- Retrieve an info text
print("Text shown: " .. info.getText())
Logger
Logging is a key element for understanding what is happening inside the controller. The Electra One Lua API provides the print() command, which sends text messages that can be viewed in the Electra One web application. Log messages created with the print() function are always prefixed with lua: text.
In fact, these log messages are SysEx messages sent to the CTRL port. They include both a timestamp and the text of the message. For more details about console logs, please review Electra One’s MIDI implementation.
Because logging uses standard SysEx messaging, users can create their own log viewers or integrate Electra logs into their own applications.
The logger output can be enabled or disabled. When disabled, no log messages are sent over MIDI. By default, the logger is disabled for performance reasons. For more information on how to manage the logger, see the section on enabling and disabling logging.
Functions
print(text)
A function to print text to the Electra One web application Console log view.
Parameters
text
Example
-- Printing to the console log
print("This message will be shown in the ElectraOne console")
for i = 1, 10 do
    print("message #" .. i)
The Example will produce following output in the Electra One web application Console
Hello world output
Message
The Message object holds the actual MIDI or virtual message that Control’s Value object sends and receives. Every Value object is linked to exactly one Message object.
Functions
<message>:setDeviceId(deviceId)
Sets the id of the device that will send and receive this message. Important: If this call creates a new ParameterMap entry, you must manually set its value.
Parameters
deviceId
number, an identifier of the device to be assigned (1 .. 32).
<message>:getDeviceId()
Retrieves the identifier of the currently assigned device.
Returns
number, an identifier of the currently assigned device (1 .. 32).
<message>:setType(type)
Sets the type of the parameter that will be processed by the Message object. For a list of message types, refer to the overview in the Globals section.
Parameters
type
number, an identifier of the Message parameter type (0 .. 16).
<message>:getType()
Retrieves the type of the parameter of the Message object. For a list of message types, refer to the overview in the Globals section.
Returns
<message>:setParameterNumber(parameterNumber)
Sets the parameter number that will be processed by the Message object.
Parameters
parameterNumber
number, a numeric identifier of the parameter (0 .. 16383).
<message>:getParameterNumber()
Retrieves the parameter number assigned to the Message object.
Returns
<message>:setValue(midiValue)
Sets the MIDI value inside the Message object. This value will be sent, processed by Lua functions, and used to update all related display values.
Parameters
midiValue
number, the MIDI value to set and send (0 .. 16383).
<message>:getValue()
Retrieves the current MIDI value assigned to the Message object.
Returns
number, the current MIDI value (0 .. 16383).
<message>:setMin(minumumValue)
Sets the minimum MIDI value of the Message object.
Parameters
minumumValue
number, the minimum MIDI value to be set.
<message>:getMin()
Retrieves the minimum MIDI value currently set for the Message object.
Returns
number, the current minimum MIDI value.
<message>:setMax(maximumValue)
Sets the maximum MIDI value of the Message object.
Parameters
maximumValue
number, the maximum MIDI value to be set.
<message>:getMax()
Retrieves the maximum MIDI value currently set for the Message object.
Returns
number, the current maximum MIDI value.
<message>:setRange(minimumValue, maximumValue)
Changes the MIDI value range of the Message object. This function is a shortcut that avoids making two separate calls to Message setMin() and setMax() functions.
Parameters
minimumValue
maximumValue
<message>:setOffValue(offValue)
Sets the MIDI value that is sent when a State control, such as a Pad, is turned off.
Parameters
offValue
number, a number representing the MIDI value used when the control is in the Off state.
<message>:getOffValue()
Retrieves the MIDI value currently set for the Message object associated with control in the Off state.
Returns
number, the current MIDI value used when the control is in the Off state.
<message>:setOnValue(onValue)
Sets the MIDI value that is sent when a State control, such as a Pad, is turned on.
Parameters
onValue
number, a number representing the MIDI value used when the control is in the On state.
<message>:getOnValue()
Retrieves the MIDI value currently set for the Message object associated with control in the On state.
Returns
number, the current MIDI value used when the control is in the On state.
Example
-- Print info about the message
function valueCallback (valueObject, value)
    local message = valueObject:getMessage ()
    print ("Device Id: " .. message:getDeviceId ())
    print ("Type: " .. message:getType ())
    print ("Parameter Number: " .. message:getParameterNumber ())
    print ("Current value: " .. message:getValue ())
<message>:print()
Prints all attributes of the Message object to the Logger output.
MIDI callbacks
MIDI callbacks are used to handle incoming MIDI messages. The general onMessage() callback is called for any incoming MIDI message, while specific callbacks are triggered only for particular message types.
When you define a callback function in your Lua script, the Electra One Lua interpreter automatically registers it. This registration adds a small processing overhead, so it's a good idea not to define empty callback functions that do nothing."
The first parameter of all callback functions is the midiInput. The midiInput is a data table that describes the origin of the message.
midiInput = {
  interface = "USB dev",  -- a name of the IO interface where the messages was received
  port = 0                -- a numeric port identifier
The midiMessage data table is another key structure. It contains information about a MIDI message, broken down into its parts. While different types of MIDI messages use slightly different formats, every midiMessage includes the fields channel, type, data1, and data2.
For example, a Control Change message can be access either as:
midiMessage = {
    channel = 1,
    type = CONTROL_CHANGE,
    data1 = 1,
    data2 = 127
or
midiMessage = {
    channel = 1,
    controllerNumber = 1,
    value = 127
The full description of all midiMessage variants is provided later in this document.
Functions
midi.onMessage(midiInput, midiMessage)
A user-defined callback function to handle all types of MIDI messages.
Parameters
midiInput
data table, a table containing information about the source of the message, (see below).
midiMessage
data table, a structured representation of the incoming MIDI message.
midi.onNoteOn(midiInput, channel, noteNumber, velocity)
A user-defined callback function to handle Note On MIDI messages.
Parameters
midiInput
channel
number, a numeric representation of the MIDI channel (1 .. 16).
noteNumber
number, a numeric representation of the MIDI note (0 .. 127).
velocity
number, a numeric representation of the MIDI note velocity (0 .. 127).
midi.onNoteOff(midiInput, channel, noteNumber, velocity)
A user-defined callback function to handle Note Off MIDI messages.
Parameters
midiInput
channel
noteNumber
velocity
midi.onControlChange(midiInput, channel, controllerNumber, value)
A user-defined callback function to handle Control Change MIDI messages.
Parameters
midiInput
channel
controllerNumber
number, a numeric representation of the Control Change parameter (0 .. 127).
value
number, a numeric representation of the Control Change value (0 .. 127).
midi.onAfterTouchPoly(midiInput, channel, noteNumber, pressure)
A user-defined callback function to handle Polyphonic Aftertouch MIDI messages.
Parameters
midiInput
channel
noteNumber
pressure
number, a numeric representation of the MIDI pressure (0 .. 127).
midi.onAfterTouchChannel(midiInput, channel, pressure)
A user-defined callback function to handle Channel Aftertouch MIDI messages.
Parameters
midiInput
channel
pressure
midi.onProgramChange(midiInput, channel, programNumber)
A user-defined callback function to handle Program Change MIDI messages.
Parameters
midiInput
channel
programNumber
number, a numeric representation of the MIDI program number (0 .. 127).
midi.onPitchBend(midiInput, channel, value)
A user-defined callback function to handle Pitch Bend MIDI messages.
Parameters
midiInput
channel
value
number, an amount of Pitch Bend to be applied (-8191 .. 8192)).
midi.onSongSelect(midiInput, songNumber)
A user-defined callback function to handle Song Select MIDI messages.
Parameters
midiInput
songNumber
number, a numeric identifier of the song (0 .. 127).
midi.onSongPosition(midiInput, position)
A user-defined callback function to handle Song Position Pointer MIDI messages.
Parameters
midiInput
position
number, a numeric of beats from the start of the song (0 .. 16383).
midi.onClock(midiInput)
A user-defined callback function to handle Clock MIDI messages. There are 24 Clock messages per quarter note.
Parameters
midiInput
midi.onStart(midiInput)
A user-defined callback function to handle Start MIDI messages.
Parameters
midiInput
midi.onStop(midiInput)
A user-defined callback function to handle Stop MIDI messages.
Parameters
midiInput
midi.onContinue(midiInput)
A user-defined callback function to handle Continue MIDI messages.
Parameters
midiInput
midi.onActiveSensing(midiInput)
A user-defined callback function to handle Active Sensing MIDI messages.
Parameters
midiInput
midi.onSystemReset(midiInput)
A user-defined callback function to handle System Reset MIDI messages.
Parameters
midiInput
midi.onTuneRequest(midiInput)
A user-defined callback function to handle Tune Request MIDI messages.
Parameters
midiInput
midi.onSysex(midiInput)
A user-defined callback function to handle SysEx MIDI messages.
Parameters
midiInput
sysexBlock
userdata, a reference to a SysexBlock object containing the SysEx data.
Example 1
-- Receiving MIDI messages
-- Receiving MIDI messages with a generic midi.onMessage() callback
function midi.onMessage(midiInput, midiMessage)
    if midiMessage.type == SYSEX then
        print("sysex message received: interface=" .. midiInput.interface)
        local sysexBlock = midiMessage.sysexBlock
        for i = 1, sysexBlock:getLength() do
            print (string.format ("data[%d] = %d", i, sysexBlock:peek(i)))
    else
        -- generic approach using the data1 and data2
        print("midi message received: interface=" .. midiInput.interface ..
              " channel=" .. midiMessage.channel ..
              " type=" .. midiMessage.type ..
              " data1=" .. midiMessage.data1 ..
              " data2=" .. midiMessage.data2)
        -- Message type specific attributes
        if midiMessage.type == NOTE_ON then
            print("noteOn received: interface=" .. midiInput.interface ..
                  " noteNumber=" .. midiMessage.noteNumber ..
                  " velocity=" .. midiMessage.velocity)
Example 2
-- Receiving MIDI messages with callbacks specific to MIDI message type
function midi.onControlChange(midiInput, channel, controllerNumber, value)
    print("controlChange received: interface=" .. midiInput.interface ..
          " channel=" .. channel ..
          " controllerNumber=" .. controllerNumber .. " value=" .. value)
function midi.onNoteOn(midiInput, channel, noteNumber, velocity)
          " noteNumber=" .. noteNumber .. " velocity=" .. velocity)
function midi.onNoteOff(midiInput, channel, noteNumber, velocity)
    print("noteOff received: interface=" .. midiInput.interface ..
function midi.onAfterTouchPoly(midiInput, channel, noteNumber, pressure)
    print("afterTouchPoly received: interface=" .. midiInput.interface ..
          " noteNumber=" .. noteNumber .. " pressure=" .. pressure)
function midi.onProgramChange(midiInput, channel, programNumber)
    print("programChange received: interface=" .. midiInput.interface ..
          " programNumber=" .. programNumber)
function midi.onAfterTouchChannel(midiInput, channel, pressure)
    print("afterTouchChannel received: interface=" .. midiInput.interface ..
function midi.onPitchBendChannel(midiInput, channel, value)
    print("pitchBend received: interface=" .. midiInput.interface ..
          " value=" .. value)
function midi.onSongSelect(midiInput, songNumber)
    print("songSelect received: interface=" .. midiInput.interface ..
          " songNumber=" .. songNumber)
function midi.onSongPosition(midiInput, position)
    print("songPosition received: interface=" .. midiInput.interface ..
          " position=" .. position)
function midi.onClock(midiInput)
    print("midi clock received: interface=" .. midiInput.interface)
function midi.onStart(midiInput)
    print("start received: interface=" .. midiInput.interface)
function midi.onStop(midiInput)
    print("stop received: interface=" .. midiInput.interface)
function midi.onContinue(midiInput)
    print("continue received: interface=" .. midiInput.interface)
function midi.onActiveSensing(midiInput)
    print("active sensing received: interface=" .. midiInput.interface)
function midi.onSystemReset(midiInput)
    print("system reset received: interface=" .. midiInput.interface)
function midi.onTuneRequest(midiInput)
    print("tune request received: interface=" .. midiInput.interface)
function midi.onSysex(midiInput, sysexBlock)
    print ("sysex message received: interface=" .. midiInput.interface)
    -- print the received data
        print(string.format ("data[%d] = %d", i, sysexBlock:peek(i)))
MIDI functions
The MIDI library provides functions for sending raw MIDI messages. There are two ways to send MIDI messages: by composing a midiMessage data table and passing it to the generic midi.sendMessage() function, or by calling dedicated functions for specific message types, such as midi.sendNoteOn().
MIDI messages can be sent to all of Electra’s interfaces (USB Dev, USB Host, MIDI IO) or just one specific interface. This depends on whether you pass an Interface Type as the first argument to the function.
The following call will send the None Off MIDI message to all available MIDI interfaces:
midi.sendNoteOff(port, channel, noteNumber, velocity)
while
midi.sendNoteOff(interface, port, channel, noteNumber, velocity)
will send it to a specific MIDI interface.
Functions
For simplicity, functions will be listed here without the leading MIDI interface parameter.
midi.sendMessage(port, midiMessage)
A function to send a MIDI message defined in `midiMessage` data table.
Parameters
port
enum, a numeric representation of the MIDI port [PORT_1, PORT_2].
midiMessage
midi.sendNoteOn(port, channel, noteNumber, velocity)
A function to send a Note On MIDI message.
Parameters
port
channel
noteNumber
velocity
A function to send a Note Off MIDI message.
Parameters
port
channel
noteNumber
velocity
midi.sendControlChange(port, channel, controllerNumber, value)
A function to send a Control Change MIDI message.
Parameters
port
channel
controllerNumber
value
midi.sendAfterTouchPoly(port, channel, noteNumber, pressure)
A function to send a Polyphonic Aftertouch MIDI message.
Parameters
port
channel
noteNumber
pressure
midi.sendAfterTouchChannel(port, channel, pressure)
A function to send a Channel Aftertouch MIDI message.
Parameters
port
channel
pressure
midi.sendProgramChange(port, channel, programNumber)
A function to send a Program Change MIDI message.
Parameters
port
channel
programNumber
midi.sendPitchBend(port, value)
A function to send a Pitch Bend MIDI message.
Parameters
port
channel
value
midi.sendSongSelect(port, songNumber)
A function to send a SongSelect MIDI message.
Parameters
port
songNumber
midi.onSongSelect(port, songNumber)
A function to send a Song Select MIDI message.
Parameters
port
songNumber
midi.sendSongPosition(port, position)
A function to send a Song Position Pointer MIDI message.
Parameters
port
position
midi.sendClock(port)
A function to send single Clock MIDI message.
Parameters
port
midi.sendStart(port)
A function to send a Start MIDI message.
Parameters
port
midi.sendStop(port)
A function to send a Stop MIDI message.
Parameters
port
midi.sendContinue(port)
A function to send a Continue MIDI message.
Parameters
port
midi.sendActiveSensing(port)
A function to send a Active Sensing MIDI message.
Parameters
port
midi.sendSystemReset(port)
A function to send a System Reset MIDI message.
Parameters
port
midi.sendTuneRequest(port)
A function to send a Tune Request MIDI message.
Parameters
port
midi.sendSysex(port)
A function to send a SysEx MIDI messages.
Parameters
port
sysexBlock
midi.sendNrpn(port, channel, parameterNumber, value, lsbFirst, reset)
A function to send a NRPN MIDI message.
Parameters
port
channel
parameterNumber
number, a numeric representation of the NRPN parameter (0 .. 16383).
value
number, a numeric representation of the Control Change value (0 .. 16383).
lsbFirst
boolean, when true the lsb and msb bytes will be swapped.
reset
boolean, when true the RPN reset will be sent at the end of the NRPN message.
midi.sendRpn(port, channel, parameterNumber, value)
A function to send a RPN MIDI message.
Parameters
port
channel
parameterNumber
value
midi.sendControlChange14(port, channel, controllerNumber, value, lsbFirst)
A function to send a 14-bit Control Change MIDI message.
Parameters
port
channel
controllerNumber
number, a numeric representation of the 14-bit Control Change parameter (0 .. 31).
value
lsbFirst
midi.flush()
A function to flush (force the sending of) all data from MIDI queues. Normally, outbound MIDI data is sent at regular time intervals. However, in certain situations, such as when a blocking call interrupts the processing users may wish to flush their MIDI data before entering the blocking call.
Example
-- Sending MIDI messages using the sendMessage ()
-- Control Change
midiMessage = {
   channel = 1,
   value = 127
midi.sendMessage(PORT_1, midiMessage)
-- Note On
midiMessage = {
   channel = 1,
   type = NOTE_ON,
   noteNumber = 60,
   velocity = 100
-- Note Off
midiMessage = {
   channel = 1,
   type = NOTE_OFF,
   noteNumber = 60,
   velocity = 100
-- Program Change
midiMessage = {
   channel = 1,
   type = PROGRAM_CHANGE,
   programNumber = 10
-- Pitch Bend
midiMessage = {
   channel = 1,
   type = PITCH_BEND,
   value = 513
-- Poly Pressure
midiMessage = {
   channel = 1,
   type = POLY_PRESSURE,
   noteNumber = 60,
   pressure = 100
-- Channel Pressure
midiMessage = {
   channel = 1,
   type = CHANNEL_PRESSURE,
   pressure = 64
-- Clock
midiMessage = {
   type = CLOCK
-- Start
midiMessage = {
   type = START
-- Stop
midiMessage = {
   type = STOP
-- Continue
midiMessage = {
   type = CONTINUE
-- Active Sensing
midiMessage = {
   type = ACTIVE_SENSING
-- System Reset
midiMessage = {
   type = RESET
-- Song Select
local ss = {
   type = SONG_SELECT,
   songNumber = 20
midi.sendMessage(PORT_1, ss)
-- Song Position
midiMessage = {
   type = SONG_POSITION,
   position = 10
-- Tune Request
midiMessage = {
   type = TUNE_REQUEST
Example
print ("Sending MIDI out demo loaded")
-- Control change
midi.sendControlChange(PORT_1, 1, 10, 64)
-- Notes
midi.sendNoteOn(PORT_1, 1, 60, 100)
midi.sendNoteOff(PORT_1, 1, 60, 100)
-- Program change
midi.sendProgramChange(PORT_1, 1, 10)
-- Pitch bend
midi.sendPitchBend(PORT_1, 1, 513)
-- Polyphonic aftertouch
midi.sendAfterTouchPoly(PORT_1, 1, 60, 100)
-- Channel aftertouch
midi.sendAfterTouchChannel(PORT_1, 1, 100)
-- Send NRPN
midi.sendNrpn(PORT_1, 1, 512, 8192)
-- Send RPN
midi.sendRpn(PORT_1, 1, 1, 4096)
-- Send Control change 14bit
midi.sendControlChange14Bit(PORT_1, 1, 1, 2048)
-- Clock
midi.sendClock(PORT_1)
-- Start
midi.sendStart(PORT_1)
-- Stop
midi.sendStop(PORT_1)
-- Continue
midi.sendContinue(PORT_1)
-- Active sensing
midi.sendActiveSensing(PORT_1)
-- System reset
midi.sendSystemReset(PORT_1)
-- Song select
midi.sendSongSelect(PORT_1, 1)
-- Song position
midi.sendSongPosition(PORT_1, 200)
-- Tune request
midi.sendTuneRequest(PORT_1)
-- SysEx
midi.sendSysex(PORT_1, { 67, 32, 0 })
Overlays
The Overlays module provides functionality for managing preset overlays. An overlay is a list of MIDI values, with each entry containing a MIDI value, a text label, and optional bitmap data. Overlays provide options for List controls and can also replace display values for Faders
Functions
overlays.get(overlayId)
Retrieves a reference to an Overlay object (Lua userdata). The overlay id number can be found in the control properties panel in the Preset Editor.
Parameters
overlayId
number, an overlay identifier.
Returns
userdata, an object representing the overlay.
overlays.create(overlayId, overlayData)
Creates a new Overlay object and returns a reference (userdata) to it. The overlay ID must be unique; otherwise, Electra will log a conflict in the debug log and overwrite the existing overlay.
Parameters
overlayId
number, an identifier of the overlay to be created.
overlayData
table, a Lua table with the overlay items data.
Returns
The Overlay Lua table must be structured as shown below. value is the MIDI value, label is a text label associated with the MIDI value.
overlayData = {
    { value = 1, label = "Room" },
    { value = 2, label = "Hall" },
    { value = 3, label = "Plate" },
    { value = 4, label = "Spring" }
Overlay
An Overlay object stores the data and functions used to manage an overlay.
<overlay>:print()
Prints all attributes of the Overlay object to the Logger output.
Example
-- Define reverb and delay types with associated values and labels
local listReverbTypes = {
-- Create a new overlay
overlays.create(2, listReverbTypes)
Pages
The pages module allows you to get information about pages, check their status, and switch from one page to another.
Functions
pages.get(pageId)
Retrieves a reference to a Page object (Lua userdata). A Page represents a named collection of controls and groups displayed on the screen at the same time.
Parameters
pageId
number, a numeric identifier of the Page (1 .. 12).
Returns
userdata, an object representing the page.
pages.getAll()
Retrieves an array of Page object references (Lua userdata) used in the preset.
Returns
array, a list of references to all pages in the preset.
pages.getActive()
Retrieves a reference to the currently active Page object (Lua userdata).
Returns
userdata, a reference to the currently active Page.
pages.display(pageId)
Changes the currently displayed page.
Parameters
pageId
pages.setActiveControlSet(controlSetId)
Switches the active Control set on the current page. It acts as a shortcut so you don’t have to manually query the active page first.
Parameters
controlSetId
enum, a numeric identifier of the Control set [CONTROL_SET_1, CONTROL_SET_2, CONTROL_SET_3].
pages.getActiveControlSet()
Retrieves the information about currently selected Control set of the active page.
Returns
pages.onChange(newPageId, oldPageId)
Parameters
newPageId
oldPageId
Example
-- Retrieve a reference to given page
local page = pages.get(3)
Page
A Page object stores its own data and provides functions to update and manage it.
Functions
<page>:getId()
Retrieves an identifier of the Page. The identifier is assigned to the Page in the preset JSON.
Returns
<page>:setName(name)
Sets a new name of the Page.
Parameters
name
string, the new name to assign to the Page.
<page>:getName()
Retrieves the current name of the Page.
Returns
string, the current name of the Page.
<page>:setHidden(shouldBeHidden)
Sets the visibility of the page. When hidden, the page does not appear in the page selection screen and is skipped when navigating to the next or previous page.
Parameters
shouldBeHidden
boolean, when true the page will be hidden.
<page>:isHidden()
Retrieves information whether or not the page is hidden and therefore inaccessible to users.
Returns
boolean, true if the page is hidden.
Example
-- change name of a pge
local page = pages.get(1)
page:setName("LPF")
print("page name: " .. page:getName())
<page>:print()
Prints all attributes of the Page object to the Logger output.
Parameter Map
The Parameter Map is the central part of the Electra Controller firmware. It keeps track of all parameter values across connected devices. Whenever a MIDI message is received, a knob is turned, or a value is changed by touch, the Parameter Map records the change, updates everything that depends on it, and sends out new MIDI messages.
Functions
parameterMap.resetAll()
Removes all entries from the Parameter Map, leaving it completely empty.
parameterMap.resetDevice(deviceId)
Resets all parameters of the given device to their initial (unset) state. Important: 'Unset' does not mean 0 or a default value; it means the value is empty and undefined.
Parameters
deviceId
number, an identifier of the device to reset (1 .. 32).
parameterMap.set(deviceId, type, parameterNumber, midiValue)
Updates the MIDI value of a specific Parameter Map entry. This will automatically send the MIDI messages and call any related Lua function callbacks.
Parameters
deviceId
type
parameterNumber
number, a numeric identifier of the Message parameter (0 .. 16383).
midiValue
parameterMap.apply(deviceId, type, parameterNumber, midiValue)
Updates a specific Parameter Map entry by applying a MIDI value fragment. It uses a logical OR between the current value and the new fragment. Afterward, the system automatically sends the MIDI messages and calls any related Lua function callbacks.
Parameters
deviceId
type
parameterNumber
midiValueFragment
number, the MIDI value to apply (0 .. 16383).
parameterMap.modulate(deviceId, type, parameterNumber, modulationValue, depth)
Temporarily changes (modulates) the MIDI value of a Parameter Map entry. The modulated value is sent, but it is not saved in the Parameter Map or processed by Lua callbacks or value formatters.
Parameters
deviceId
type
parameterNumber
modulationValue
float, a modulation signal to be applied (-1.0 .. 1.0).
depth
number, a depth of the modulation signal (0 .. 100).
parameterMap.updateValue(deviceId, type, parameterNumber, midiValue)
Updates the MIDI value of a specific Parameter Map entry. Unlike the set() function, no MIDI messages are sent and no Lua callbacks are invoked.
Parameters
deviceId
type
parameterNumber
midiValue
parameterMap.get(deviceId, type, parameterNumber)
Retrieves the current MIDI value stored in the Parameter Map entry. This function is equivalent to calling message:getValue() on a Message object with the corresponding attributes.
Parameters
deviceId
type
parameterNumber
parameterMap.getValues(deviceId, type, parameterNumber)
Retrieves a list of all Value objects linked to the Parameter Map entry. These are the Value objects that will be updated when the MIDI value changes.
Parameters
deviceId
type
parameterNumber
parameterMap.onChange(valueObjects, origin, midiValue)
Parameters
valueObjects
array, a list of references to userdata Value objects associated with the ParameterMap entry.
origin
number, a numeric identifier of the change origin (see [Globals](./luaext.html#globals) for details).
midiValue
number, the current MIDI value of the ParameterMap entry (0 .. 16383).
Example
-- Display info about the change in the ParameterMap
function parameterMap.onChange(valueObjects, origin, midiValue)
    print(string.format ("a new midiValue %d from origin %d",
        midiValue, origin))
            print(string.format("affects control value %s.%s",
parameterMap.keep()
Saves the current state of the Parameter Map so it can be recalled later. The data stays safely stored in the controller even when it is powered off.
parameterMap.recall()
Recalls state that was previously saved with parameterMap.keep() function call.
parameterMap.forget()
Removes and forgets state that was previously saved with parameterMap.keep() function call.
parameterMap.print()
Prints all attributes of the ParameterMap entries to the Logger output.
Patch
This library helps you request patch dumps and process SysEx MIDI messages that contain patch data. The patch.onResponse() function is called automatically when a SysEx message matches the response header you defined in the preset JSON.
To use patch callbacks, you must first create a Patch object in the Device object defined in your preset JSON.
The example below shows the simplest Patch setup. Here, patch.onResponse() will be triggered whenever a SysEx message begins with the bytes 67, 0, 0, 1, 27.
JSON
"patch":[
      "responses":[
            "id":1,
            "header":[
               67,
               0,
               0,
               1,
               27
Functions
A callback used to send a patch request to a specific device. The function is called when the [PATCH REQUEST] button is pressed, and it sends the request to all devices that have a patch request defined in their patch configuration.
Parameters
device
data table, a device description data structure (see below).
patch.onResponse(device, responseId, sysexBlock)
A callback to handle incoming SysEx message that matched the Patch response definition.
Parameters
device
responseId
number, an identifier of the response, as defined in the preset JSON.
sysexBlock
userdata, a reference to a SysexBlock object containing the received and matched SysEx message.
patch.requestAll()
Sends patch requests to all connected devices.
Example
-- Issue a patch requests
patch.requestAll()
-- Send a program change
    print ("Requesting patches...");
    if (device.id == 1) then
-- Parse an incoming response
function patch.onResponse(device, responseId, sysexBlock)
    -- print the header information
    print("device id = " .. device.id)
    print("device channel = " .. device.channel)
    print("device port = " .. device.port)
    print("responseId = " .. responseId)
    print("manufacturer Id = " .. sysexBlock:getManufacturerSysexId())
        print("data[" .. i .. "] = " .. sysexBlock:peek(i))
        -- update two parameters
    parameterMap.set(device.id, PT_CC7, 1, sysexBlock:peek(7));
    parameterMap.set(device.id, PT_CC7, 2, sysexBlock:peek(8));
Device data table
device = {
  id = 1,                 -- a device Id
  channel = 1,            -- a channel number
Preset
The preset library offers functions and callbacks to manage events that happen when working with presets.
Functions
preset.onLoad()
A callback function that is called immediately after the preset is loaded, but before the default values are initialized.
preset.onReady()
A callback function that is called when the preset is fully initialized and ready to be used.
A callback function that is called when user actives the preset by changing currently selected preset slot.
preset.onLeave()
A callback function that is called when user leaves the preset in order to switch to another preset slot.
preset.onExit()
A callback function that is called when preset is removed from the controller. Note, it is not called when user switches to another preset.
Tables
preset.userFunctions
The preset.userFunctions table allows you to define up to twelve custom Lua functions that can be triggered from the Preset Menu on the Electra One controller.
Each function is assigned to one of the predefined keys: pot1 through pot12. These correspond to the twelve on-screen buttons in the Preset Menu and match the layout of the physical knobs.
Each entry is a table that defines:
  • call – The Lua function that will be executed when the button is triggered. This is a required field.
  • name – The label that will appear on the on-screen button. This is a required field.
  • close – A boolean value that, when set to true, causes the Preset Menu to close after the function has been executed. This field is optional.
Only the assigned slots will be displayed in the menu. Buttons with a user function appear in blue, and when enabled in the configuration, functions can also be triggered by knob touch.
For more information on enabling knob touch interaction, see: Settings → Interface → Pot Touch Selections.
Example
-- Register the functions for use in the Preset Menu
preset.userFunctions = {
    pot1 = {
        call = printHello,
        name = "Hello",
        close = true
    pot2 = {
        call = printHi,
        name = "Hi",
        close = false
    pot12 = {
        call = printGoodBye,
        name = "GoodBye",
        close = false
SysEx byte function
A SysEx byte function is used in SysEx templates, patch requests, and patch response headers to calculate and insert bytes at specific positions within a SysEx message.
The function is given information about the device and a parameter number, and it must return one byte containing a 7-bit value.
Example preset JSON
This example shows how Lua functions are used in both the patch request and the response header. Here, they are used to request and match a SysEx patch dump from a TX7 on a specific MIDI channel.
JSON
"devices":[
      "id":1,
      "name":"Yamaha DX7",
      "port":1,
      "channel":16,
      "patch":[
            "request":[
               "43",
                  "type":"function",
                  "name":"getRequestByte"
               "00"
            "responses":[
                  "header":[
                     "43",
                        "type":"function",
                        "name":"getResponseByte"
                     "00",
                     "01",
                     "1B"
                  "rules":[
                        "id":136,
                        "pPos":0,
                        "byte":136,
                        "bPos":0,
                        "size":1,
                        "msg":"sysex"
The following snippet shows how to use the Lua SysEx byte function in the SysEx template.
JSON
"values":[
	  "id":"value",
	  "message":{
		 "type":"sysex",
		 "deviceId":1,
		 "data":[
			"43",
			   "type":"function",
			   "name":"getChannelByte"
			"00",
			"66",
			   "type":"value",
			   "rules":[
					 "parameterNumber":102,
					 "bitWidth":5,
					 "byteBitPosition":0
		 "min":0,
		 "max":31
	  "min":0,
	  "max":31
Functions
<sysexByteFunction>(deviceObject, value)
A function that calculates a SysEx byte and inserts it into a specific position of a SysEx message.
Parameters
deviceObject
userdata, a reference to a userdata Device object.
value
number, a numeric display value (0 .. 16383).
Example
-- returns a byte that TX7 uses to identify the MIDI channel
function getChannelByte(device)
    return (0x10 + (device:getChannel() - 1))
SysexBlock
An object designed to handle SysEx messages.
In contrast to simple byte arrays, SysexBlock provides efficient tools for working with large SysEx messages, offering stream-like operations such as read, write, and peek.
Functions
<sysexBlock>:getLength()
Retrieves the total length of the SysEx message. The length includes the leading and trailing 0xF0 and 0xF7 bytes.
Returns
number, size of the SysEx message in bytes.
<sysexBlock>:getManufacturerSysexId()
Retrieves the SysEx manufacturer identifier from the SysexBlock object. It is either one byte-wide number or a number componsed of the three bytes with LSB at position 3 and MSB at position 1.
Returns
number, a numeric identifier of the manufacturer's SysEx Id.
<sysexBlock>:seek(position)
Sets the SysexBlock's current position at given ofset. The leading 0xF0 byte is at position 1.
Parameters
position
number, the position of the read/write pointer in the SysexBlock.
<sysexBlock>:read()
Reads one byte from the current position within the SysexBlock. The read/write pointer is automatically increased after the read is completed.
Returns
number, a byte stored at current read/write pointer in the SysexBlock, or -1 on failure.
<sysexBlock>:peek(position)
Reads one byte from the given position within the SysexBlock. The read/write pointer is NOT set or modified by calling this function.
Parameters
position
number, the position of the byte to read
Returns
<sysexBlock>:write(byte)
Writes one byte to the current position of the SysexBlock. The read/write pointer is automatically increased after the write is completed.
Parameters
byte
number, a byte value to be stored at the position of the read/write pointer in the SysexBlock.
<sysexBlock>:close()
Closes the SysexBlock, stopping any further writing. You must always close a SysexBlock before using it.
System
The System module offers functions that control system behavior and manage tasks.
Functions
persist(table)
Saves a Lua table to non-volatile memory, allowing the data to be restored after the controller is powered off or restarted.
Parameters
table
data table, a Lua table to be saved for later use.
recall(table)
Loads saved data from non-volatile memory and updates the provided Lua table with the retrieved values.
Parameters
table
Data table, a Lua table to be updated with the restored data.
yield()
Suspends the execution of the current function, allowing other tasks to run. The function that called yield() will automatically resume once all higher-priority tasks have been completed.
Timer
The timer library lets you run tasks repeatedly over time. It calls the timer.onTick() function at a set time interval or based on BPM (beats per minute). You can use it to create MIDI clocks, LFOs, and other ongoing processes. The timer is disabled by default, and the starting rate is 120 BPM.
Functions
timer.enable()
Enables the timer. Once the timer is enabled, the timer.onTick() is run at given time periods.
timer.disable()
Disables the timer. The period of the timer is kept.
timer.isEnabled()
Retrieves the information whether or not the timer is enabled.
Returns
boolean, true when the timer is enabled.
timer.setPeriod(period)
Sets the period in milliseconds at which the timer.onTick() function will be called.
Parameters
period
number, a period specified in milliseconds (10..60000).
timer.getPeriod()
Retrieves the current period in milliseconds at which the timer.onTick() function is called.
Returns
timer.setBpm(bmp)
Sets the timer rate in beats per minute (BPM) at which the timer.onTick() function will be called."
Parameters
bpm
number, a BPM use to run the timer function.
timer.getBpm()
Retrieves the current timer rate in beats per minute (BPM) used to call the timer.onTick() function.
Returns
timer.onTick()
A user function callback that will be run at the start of every timer cycle.
Example
-- A naive MIDI LFO implementation
faderValue = 0
timer.enable()
timer.setBpm(120 * 16)
function timer.onTick ()
    parameterMap.set(1, PT_CC7, 1, faderValue)
    faderValue = math.fmod(faderValue + 1, 127)
Transport
The transport library works like the timer but doesn't generate its own tick signal. Instead, it uses MIDI real-time system and clock messages from an external source. This lets you create processes that stay in sync with an external MIDI clock. The transport is disabled by default.
Functions
transport.enable()
Enables the transport. Once the transport is enabled, the transport.onClock() is run at according to the received MIDI clock messages.
transport.disable()
Disables the transport. The transport.onClock() will not be called until it is enabled again.
transport.isEnabled()
Retrieves the information whether or not the transport is enabled.
Returns
boolean, true when the transport is enabled.
transport.onClock(midiInput)
A user-defined callback function that is called on every incoming MIDI Clock message. There are 24 Clock messages per quarter note.
Parameters
midiInput
transport.onStart(midiInput)
Parameters
midiInput
transport.onStop(midiInput)
Parameters
midiInput
transport.onContinue(midiInput)
Parameters
midiInput
transport.onSongSelect(midiInput, songNumber)
Parameters
midiInput
songNumber
transport.onSongPosition(midiInput, position)
Parameters
midiInput
position
Example
faderValue = 0
function preset.onLoad()
  if (not transport.isEnabled()) then
    transport.enable()
  print("Transport enabled: " .. (transport.isEnabled() and "yes"  or "no"))
function transport.onClock(midiInput)
  faderValue = faderValue + 1
  if (faderValue > 127) then
    faderValue = 0
function transport.onStart(midiInput)
  print("Start")
function transport.onStop(midiInput)
  print("Stop")
function transport.onContinue(midiInput)
  print("Continue")
function transport.onSongSelect(midiInput, songNumber)
  print("Song select " .. songNumber)
function transport.onSongPosition(midiInput, position)
  print("Song position " .. position)
MIDI input data table
For more details refer to Data structures section.
midiInput = {
  interface = USB_DEV,  -- an numeric MIDI interface identifier
Value
A Value object represents a single data value inside a Control. Each Value is identified by a valueId, and a Control can have one or more Values. The Value object describes the data users can change through interaction and provides functions to access and modify that data."
Functions
<value>:getId()
Retrieves the identifier of the Value - valueId. The identifier is assigned to the Value in the preset JSON.
Returns
<value>:setName(name)
Sets a new name of the value.
Parameters
name
string, the new name to assign to the control value.
<value>:getName()
Retrieves the current name of the value.
Returns
string, the current name assigned to the value.
<value>:setDefault(defaultValue)
Sets the default display value of the Value object.
Parameters
defaultValue
number, the default display value to be set.
<value>:getDefault()
Retrieves the default display value currently set for the Value object.
Returns
number, the current default display value.
<value>:setMin(minumumValue)
Sets the minimum display value of the Value object.
Parameters
minumumValue
number, the minimum display value to be set.
<value>:getMin()
Retrieves the minimum display value currently set for the Value object.
Returns
number, the current minimum display value.
<value>:setMax(maximumValue)
Sets the maximum display value of the Value object.
Parameters
maximumValue
number, the maximum display value to be set.
<value>:getMax()
Retrieves the maximum display value currently set for the Value object.
Returns
number, the current maximum display value.
<value>:setRange(minimumValue, maximumValue, defaultValue, applyToMessage)
Changes the display value range of the Value object and, if needed, updates the underlying Message object as well. This function is a shortcut that avoids making many separate calls to Value and Message setters.
Parameters
minimumValue
maximumValue
defaultValue
applyToMessage
boolean, when true, the same range is applied to underlying Message object.
<value>:setOverlayId(overlayId)
Assigns an overlay list to the Value object. The overlayId is defined in the preset JSON or created using the overlays.create() function.
Parameters
overlayId
number, an identifier of the overlay.
<value>:getOverlayId()
Retrieves the overlayId currently assigned to the Value object.
Returns
Example
--  swap overlay lists of two controls
local listA = controls.get(1)
local listB = controls.get(2)
local valueA = listA:getValue("value")
local valueB = listB:getValue("value")
print("list A: " .. valueA:getOverlayId())
print("list B: " .. valueB:getOverlayId())
valueB:setOverlayId(1)
valueA:setOverlayId(2)
<value>:overrideValue(valueText)
Replaces the current value with custom text on the control's display. This custom text also overrides the output from Value Formatters.
Parameters
valueText
string, a text to be displayed instead of current display value.
<value>:cancelOverride()
Clears the overridden text set by <value>:overrideValue() and restores the display of the current value."
<value>:getMessage()
Retrieves the Message object assigned to the Value object.
Returns
userdata, a reference to the Message object.
Example
-- Get the message associated with the release value
local value = control:getValue("release")
local message = value.getMessage()
<value>:getControl()
Retrieves the Control object that this Value belongs to.
Returns
userdata, a reference to the Control object.
<value>:getValue()
Retrieves the current display value of the Value object.
Returns
number, the current display value.
<value>:print()
Prints all attributes of the Value object to the Logger output.
Value formatters
A value formatter is a custom function that formats how a control's value is displayed. It receives a display value as input and returns a new value as a string. This allows users to customize how information appears on the screen in many different ways.
To use a formatter, you must assign it to a Value in the preset JSON by adding a formatter attribute to the Value object.
The value formatter runs automatically whenever the underlying MIDI value changes.
Example preset JSON
JSON
"values": [
      "message": {
         "deviceId": 1,
         "type": "cc7",
         "parameterNumber": 2,
         "min": 0,
         "max": 127
      "id": "value",
      "min": 0,
      "max": 127,
      "formatter": "formatFractions"
For more detailed information about the preset JSON, visit the Preset JSON format page.
Functions
<formatterFunction>(valueObject, value)
A user-defined function that transforms the input display value into a text string shown on the screen.
Parameters
valueObject
userdata, a reference to a userdata Value object that was changed.
value
number, a new display value to be formatted.
Example
-- Convert number to a range with decimal numbers
function formatFractions(valueObject, value)
    return (string.format("%.1f", value / 20))
-- add percentage to the value
function addPercentage(valueObject, value)
    return (value .. "%")
Value function callbacks
A value function callback is a user-defined function that lets you run custom actions whenever a control's value changes.
To use a callback, you must assign it to a Value in the preset JSON by adding a function attribute to the Value object. You can think of a callback as a flexible alternative to a Message:
while a Message sends a fixed MIDI command, a function runs dynamic Lua code when the value changes.
Example preset JSON
JSON
"values": [
      "message": {
         "deviceId": 1,
         "type": "cc7",
         "min": 0,
         "max": 127
      "id": "attack",
      "min": 0,
      "max": 127,
      "function": "highlightOnOverload"
Functions
<customFunction>(valueObject, value)
A user-defined function that to execute Lua code whenever control's value changes.
Parameters
valueObject
value
number, a new display value to be processed.
Example
function highlightOnOverload (valueObject, value)
    if (value > 64) then
        control:setColor (ORANGE)
    else
        control:setColor (WHITE)
Window
The Window library gives you control over the graphic component repainting process.
Functions
window.repaint()
Forces repaint of the current window.
window.stop()
Stops automatic repainting of components. This helps when updating many controls at once. By using window.stop() before and window.resume() after your updates, you can speed up the process and display all changes together.
window.resume()
Resumes the process of automatic repainting of components. The complete repaint of whole window is forced at the moment when the repainting process is resumed.
Data structures
midiInput
midiInput is a data table that describes the origin of incoming MIDI messages. The consists of information about the MIDI interface and the port identifier.
  • interface - integer, an identifier of Electra's MIDI interface. (see Globals for details).
  • port - integer, a port identifier (see Globals for details).
Example
midiInput = {
  interface = MIDI_IO,  -- a name of the IO interface where the messages was received
  port = PORT_1                -- a numeric port identifier
midiMessage
The midiMessage data table carries the information about a MIDI message broken down do individual attributes. Different types of MIDI messages are represented with slightly different format of the midiMessage data table. The fields channel, type, data1, data2 are, however, common to all types of messages.
midiMessage = {
    channel = 1,
    data1 = 1,
    data2 = 127
or
midiMessage = {
    channel = 1,
    value = 127
  • channel - integer, a numeric representation of the MIDI channel (1 .. 16).
  • type - integer, an identifier of the MIDI message type (see Globals for details).
  • data1 - integer, the first data byte of MIDI message (0 .. 127).
  • data2 - integer, the second data byte of MIDI message (0 .. 127).
  • MIDI message type specific attrbutes are listed below.
Attributes specific to MIDI message types
MIDI message typeAttributes
NOTE_ONnoteNumber
velocity
NOTE_OFFnoteNumber
velocity
CONTROL_CHANGEcontrollerNumber
value
POLY_PRESSUREnoteNumber
pressure
CHANNEL_PRESSUREpressure
PROGRAM_CHANGEprogramNumber
PITCH_BENDvalue
SONG_SELECTsongNumber
SONG_POSITIONsongPosition
Globals
The global variables are used to identify common constants that can be used instead of numbers.
Hardware ports
Identifiers of the MIDI ports.
  • PORT_1
  • PORT_2
  • PORT_CTRL
Interfaces
Types of MIDI interfaces.
  • MIDI_IO
  • USB_DEV
  • USB_HOST
Change origins
Identifiers of the sources of the MIDI value change. Origin is passed as a parameter of the ParameterMap onChange callback.
  • INTERNAL
  • MIDI
  • LUA
Parameter types
Types of Electra MIDI parameters. These types are higher abstraction of the standard MIDI message types.
  • PT_VIRTUAL
  • PT_CC7
  • PT_CC14
  • PT_NRPN
  • PT_RPN
  • PT_NOTE
  • PT_PROGRAM
  • PT_SYSEX
  • PT_START
  • PT_STOP
  • PT_TUNE
  • PT_ATPOLY
  • PT_ATCHANNEL
  • PT_PITCHBEND
  • PT_SPP
  • PT_RELCC
  • PT_NONE
Control sets
Identifiers of the control sets. The control sets are groups of controls assigned to the pots.
  • CONTROL_SET_1
  • CONTROL_SET_2
  • CONTROL_SET_3
Pots
Identifiers of the hardware pots. The pots are the rotary knobs to change the control values.
  • POT_1
  • POT_2
  • POT_3
  • POT_4
  • POT_5
  • POT_6
  • POT_7
  • POT_8
  • POT_9
  • POT_10
  • POT_11
  • POT_12
Colors
Identifiers of standard Electra colors.
  • WHITE
  • RED
  • ORANGE
  • BLUE
  • GREEN
  • PURPLE
Variants
  • VT_DEFAULT
  • VT_HIGHLIGHTED
  • VT_THIN
  • VT_VALUEONLY
  • VT_DIAL
  • VT_CHECKBOX
Bounding box
Identifiers of individual attributes of the bounding box (bounds).
  • X
  • Y
  • WIDTH
  • HEIGHT
MIDI message types
Identifiers of standard MIDI messages.
  • CONTROL_CHANGE
  • NOTE_ON
  • NOTE_OFF
  • PROGRAM_CHANGE
  • POLY_PRESSURE
  • CHANNEL_PRESSURE
  • PITCH_BEND
  • CLOCK
  • START
  • STOP
  • CONTINUE
  • ACTIVE_SENSING
  • RESET
  • SONG_SELECT
  • SONG_POSITION
  • TUNE_REQUEST
  • TIME_CODE_QUARTER_FRAME
  • SYSEX
Controller events
Flags indentifying individual types of events.
  • NONE
  • PAGES
  • CONTROL_SETS
  • USB_HOST_PORT
  • POTS
  • TOUCH
  • BUTTONS
  • WINDOWS
Touch events
Identifiers of touch events used in the Touch callbacks.
  • DOWN
  • MOVE
  • UP
  • CLICK
  • DOUBLECLICK
Curve segments
Identifiers of the curve segments used in the graphics module.
  • TOP_LEFT
  • TOP_RIGHT
  • BOTTOM_LEFT
  • BOTTOM_RIGHT
Controller models
Identifiers of the Electra One hardware models.
  • MODEL_ANY
  • MODEL_MK1
  • MODEL_MK2
  • MODEL_MINI_MK1
Horizontal alignment
Text alignment modes
  • LEFT
  • CENTER
  • RIGHT
