What Is a Value? ​
A value is a piece of data that a program works with. In Lua, everything you store or manipulate is a value.
Examples of values:
  • 10
  • "hello"
  • true
  • nil
Values have a type, which tells Lua how to treat them.
Basic Value Types in Lua ​
Lua has a small number of core types:
  • Number – numeric values (integers and decimals)
  • String – text enclosed in quotes
  • Boolean – logical values: true or false
  • Nil – represents “no value”
  • Table – collections of values (covered in detail later)
  • Function – executable values (covered later)
For now, we focus on the first four.
Numbers ​
Numbers represent quantities and can be used in calculations.
Examples:
  • 5
  • 3.1
  • -20
Common arithmetic operators:
    • addition
    • subtraction
    • multiplication
  • / division
  • % remainder
Lua treats all numbers as the same numeric type.
Strings ​
Strings represent text. They are written using:
  • Double quotes: "Hello"
  • Single quotes: 'Hello'
Strings can contain letters, numbers, and symbols.
Common string operations:
  • Concatenation using ..
  • Length using #
Strings are immutable, meaning they cannot be changed in place.
Booleans ​
Booleans represent truth values:
  • true
  • false
They are mainly used in conditions and logic.
Important rule: Only false and nil are considered false. Everything else is considered true.
Nil ​
nil represents the absence of a value. Uses of nil:
  • Indicating that something does not exist
  • Removing values from tables
  • Representing “unknown” or “not set”
Accessing an undefined variable results in nil.
What Is a Variable? ​
A variable is a name that refers to a value. In Lua, variables are created by assignment.
x = 10
name = "Lua"
Assigning and Reassigning Variables ​
Variables can be reassigned to new values at any time. Example:
score = 100
score = 150
Local and Global Variables ​
Variables are either global or local. Global variables are accessible everywhere Local variables exist only within a limited scope
local count = 5
Using local is recommended to avoid unintended side effects.
Naming Rules and Conventions ​
Variable names:
  • Can contain letters, numbers, and underscores
  • Must not start with a number
  • Are case-sensitive
Common conventions:
  • snake_case for variables
  • Descriptive names over short ones
