Functions ​
Functions allow you to group code into reusable units. Instead of repeating the same logic in multiple places, a function lets you write it once and call it whenever needed. In Lua, functions are values, which means they can be stored in variables, passed to other functions, and placed inside tables.
Defining a Function ​
A function is defined using the function keyword.
function greet()
    print("Hello!")
The function does nothing until it is called.
greet()
Function Parameters ​
Functions can accept input values called parameters.
function greet(name)
    print("Hello, " .. name)
greet("Lua")
Parameters are local to the function.
Returning Values ​
Functions can return values using the return statement.
function add(a, b)
    return a + b
local result = add(3, 5)
print(result)
When return is executed, the function stops immediately.
Multiple Return Values ​
Lua functions can return more than one value.
function divide(a, b)
    return a / b, a % b
local quotient, remainder = divide(10, 3)
If fewer variables are used, extra return values are discarded.
Functions as Values ​
Functions can be assigned to variables.
local say_hello = function()
    print("Hello!")
say_hello()
This allows functions to be passed around like any other value.
Local and Global Functions ​
Functions can be global or local.
function global_func()
    print("I am global")
local function local_func()
    print("I am local")
Using local functions is recommended to avoid polluting the global namespace.
Functions in Tables ​
Functions are often stored in tables.
local math_utils = {}
function math_utils.square(x)
    return x * x
print(math_utils.square(4))
This pattern is commonly used for modules and objects.
The : Syntax and self ​
Lua provides a special syntax for functions that operate on tables.
local player = {
    name = "Alex"
function player:print_name()
    print(self.name)
player:print_name()
The : syntax automatically passes the table as the first argument, called self. This is equivalent to:
function player.print_name(self)
    print(self.name)
Scope and Lifetime ​
Variables defined inside a function exist only while the function runs.
function test()
    local x = 10
-- x is not accessible here
This helps prevent unintended interactions between parts of the program.
Common Mistakes ​
Forgetting to return a value:
function sum(a, b)
    a + b  -- no return
Mixing . and : incorrectly:
player.print_name()   -- wrong
player:print_name()  -- correct
Functions are reusable blocks of code. They can accept parameters, return values, and be treated like any other value. Functions stored in tables form the basis for modules and objects. Understanding how functions and tables work together is essential for writing structured Lua programs.
