RPN and NRPN (Registered and Non-Registered Parameter Numbers) ​
Why RPN and NRPN Exist ​
Standard Control Change messages are limited:
  • only 128 controller numbers
  • many already have fixed meanings
  • not enough for complex instruments
RPN and NRPN provide a way to control many more parameters, including:
  • pitch bend range
  • tuning
  • vibrato depth
  • manufacturer-specific parameters
They do this by turning CC messages into a parameter selection + value system.
Key Idea: “Select a Parameter, Then Set Its Value” ​
RPN and NRPN work in two steps:
  • Select which parameter you want to control
  • Send the value for that parameter
This is very similar to:
“Choose a knob, then turn it”
What RPN and NRPN Mean ​
  • RPN — Registered Parameter Number Standardized parameters defined by the MIDI specification
  • NRPN — Non-Registered Parameter Number Manufacturer-defined parameters (device-specific)
Both use the same mechanism, only the parameter meaning differs.
How Parameters Are Selected ​
RPN:
PurposeCCRole
RPN MSB101Parameter MSB
RPN LSB100Parameter LSB
NRPN:
PurposeCCRole
NRPN MSB99Parameter MSB
NRPN LSB98Parameter LSB
These CCs select which parameter will receive the value.
How Values Are Sent ​
Once a parameter is selected, its value is sent using Data Entry CCs:
CCPurpose
6Data Entry MSB
38Data Entry LSB (optional)
This gives you 7-bit or 14-bit resolution, just like high-resolution CC.
Complete RPN Message Flow (Example) ​
Example: Pitch Bend Range
Pitch Bend Range is a standard RPN.
Parameter number:
  • MSB = 0
  • LSB = 0
Step 1: Select the RPN
CC 101 = 0
CC 100 = 0
Step 2: Send the Value
CC 6 = 2
This sets pitch bend range to ±2 semitones.
Complete NRPN Message Flow (Example) ​
NRPN works exactly the same, but with different CCs.
Step 1: Select the NRPN
CC 99 = <MSB>
CC 98 = <LSB>
CC 6  = <MSB>
CC 38 = <LSB>   (optional)
14-bit Values with RPN / NRPN ​
Just like 14-bit CC:
  • CC 6 → coarse value
  • CC 38 → fine value Combined as:
value = MSB * 128 + LSB
Why This Is Powerful ​
RPN and NRPN allow:
  • thousands of parameters
  • high-resolution values
  • backward compatibility
  • standardized control where possible
All using existing CC infrastructure.
Important: RPN and NRPN Are “Sticky” ​
Once selected:
  • the parameter remains active
  • future Data Entry messages continue to affect it
This can cause problems if not handled carefully.
RPN Reset (Very Important) ​
###What Is RPN Reset? RPN Reset clears the currently selected RPN parameter so that further Data Entry messages do nothing accidentally. How to Reset RPN Selection
Send:
CC 101 = 127
CC 100 = 127
This means: “No RPN selected”
Why RPN Reset Is Critical ​
If you don’t reset:
  • later CC 6 messages may change the wrong parameter
  • bugs can appear far from their cause
  • behavior becomes unpredictable
Best practice:
  • Always reset RPN after setting a value.
NRPN Reset ​
NRPN has a similar reset:
CC 99 = 127
CC 98 = 127
RPN and NRPN extend MIDI Control Change by introducing a parameter-selection mechanism followed by Data Entry messages. RPN parameters are standardized, while NRPN parameters are device-specific. Both support high-resolution values and require careful handling, including resetting the selected parameter after use. Mastering RPN and NRPN is essential for advanced MIDI control.
